Postby Admin-bloke » Fri Mar 09, 2018 3:01 pm
Great pictures, add more as it's progressing
Postby A Van » Sat Mar 10, 2018 8:44 am
Nice work again!
Postby gruffalo » Sat Mar 10, 2018 12:57 pm
Disassembly still going smoothly. Clutch is 7mm, keep or replace?
Postby gruffalo » Sat Mar 10, 2018 4:45 pm
Working on swapping over the engine bottom now. Lots of cleaning to do. Hopefully getting that done today, and the cams and rockers tomorrow.
Dmc engine robbed of parts
Volvo engine ready to receive dmc bottom end
Cleaning parts to swap over
Parts are piling up
Postby bandit » Sat Mar 10, 2018 4:47 pm
If ever you have a gearbox off from the engine & you are not 100% sure of the clutch age etc, whilst it’s apart I would always bang a new one in
Postby gruffalo » Sat Mar 10, 2018 6:02 pm
bandit wrote:If ever you have a gearbox off from the engine & you are not 100% sure of the clutch age etc, whilst it’s apart I would always bang a new one in
Totally makes sense considering the work involved
Postby gruffalo » Mon Mar 12, 2018 11:15 pm
A new clutch along with some other parts are on their way.
Today was spent mostly cleaning parts. I had some success using oven cleaner, but the majority of the work was done using kerosene and a small paint brush.
I also disassembled one rocker shaft and cam. Luckily very little wear to be found.
On the other hand on 4 out of 6 rockers the lubrication hole was completely clogged. One was so bad that I struggled for a long time getting it open with a needle. There’s no way that one would have come open by itself! On a different one I managed to pull the clog out with pliers. (See photo).
Clog pulled from oiling spray hole!!!
5-6 cam and rocker assembly
Sandwich plate getting better
Finally showing bare metal
Postby gruffalo » Wed Mar 14, 2018 12:31 pm
I was planning to start assembly, but couldn't find my torque wrench. I'll bet it shows up again when I buy a new one :|
I also need to get a clutch alignment tool.
Postby Spudmurphy » Wed Mar 14, 2018 1:29 pm
loving this !! Nice one.
Postby Domi » Wed Mar 14, 2018 8:34 pm
Amazing work so far :thumbsup:
