Postby DJK73 » Sat Apr 14, 2018 8:58 am
What are you reading online?
The guy who rebuilt my engine struggled with the timing as the new chains I supplied didn't have marks.
http://www.tmproductions.com/repairs-an ... lve-timing
I found this and sent it to him and he managed to sort it. Hope it helps
Dbro4
Ex Vin#10223
Grey interior, Manual
Free flow
DJK73
VIN #: 10223
Postby gruffalo » Sat Apr 14, 2018 9:49 am
DJK73 wrote:Also are you 100% sure you have put the chains on correctly, are they original chains with painted marks on the links? Or are they new without marks?
Crank relative to piston is not affected by the chain.
Postby gruffalo » Sat Apr 14, 2018 9:51 am
Thanks for all the input guys, I’ll compare my engines and figure it out in the end :)
Postby gruffalo » Sun Apr 15, 2018 7:34 am
The notch (bottom arrow) or the round hole (top arrow)?
8mm bolt dropping into where?
Postby gruffalo » Sun Apr 15, 2018 7:36 am
And is the woodruff key somehow aligned with the #1 crank?
Postby gruffalo » Mon Apr 16, 2018 9:20 pm
Bottom arrow, I finally figured it out :)
Postby gruffalo » Tue Apr 17, 2018 9:07 pm
Success! :)
Today I did something interesting! I’ve been sorta paranoid about the oiling system not working properly. Seeing the cam wear, reading horror stories and listening to people talking down the prv got to me. So I decided I wanted to verify the function of the oiling system.
So I installed the oil pan, filter, pressure sensors and filled the sump with 4 liters of oil.
Then I started to crank the oil pump by hand. (Chain not fitted) This was very interesting and exciting!
After about 15 sec oil reached the pump, and it got a lot heavier. Next oil started pouring over the chains. A lot. At first it seemed excessive. But I kept it up, and it got even heavier at it reached the rocker shafts (which are pipes, really). And in the end I could see oil seeping out of each rocker . Hooray!!!!!
Now I can close the timing cover with peace of mind.
Postby Admin-bloke » Tue Apr 17, 2018 10:25 pm
Excellent work :thumbsup: :jzd:
Postby gruffalo » Tue Apr 17, 2018 10:59 pm
Yeah, now that I finally feel that I have everything under control, I can continue assembly in a more speedy fashion :)
Maybe I can have the whole lump ready to be dropped into the car this weekend. The forecast says rain, which means garage time!
Postby A Van » Wed Apr 18, 2018 7:15 am
At least you don’t need to worry about that part anymore!
