MEC'S EPIC RESTORATION
Postby mec » Sat Sep 29, 2018 7:54 pm
Hi All
Right then 1st things 1st, how many times have you lot heard me say... I'm going to repair that when i do the body off restoration ???
Well I've finally put into action the epic plan to sort everything out, so it started off with an idea of making use of the RSJ that runs across the middle of my garage and use to RSJ trolleys and 2 chain winches to lift some sort of brackets to lift the body off, this would act the same way as a 2 post ramp and leave the middle of the car free to lift the body off the chassis.
I started off getting these ...
20180821_134213 (Medium).jpg (264.38 KiB) Viewed 8267 times
20180821_134220 (Medium).jpg (328.14 KiB) Viewed 8267 times
After this i then started thinking about what i could make to lift the body up and came up with this ...
20180829_143237 (Medium).jpg (285.33 KiB) Viewed 8267 times
20180829_162628 (Medium).jpg (386.6 KiB) Viewed 8267 times
20180830_111603 (Medium).jpg (354.39 KiB) Viewed 8267 times
Then for a test fit ...
20180830_113745 (Medium).jpg (206.66 KiB) Viewed 8267 times
I then added another piece of wood on the back of the main square from which fits into the recess under the car and bolt through the seat mounting holes, this prevents the brackets from slipping out from under the car...
20180904_221035 (Medium).jpg (283.53 KiB) Viewed 8267 times
After a few more tweaks and modification i ended up with these ...
20180928_135205 (Medium).jpg (381.4 KiB) Viewed 8267 times
20180928_135218 (Medium).jpg (376.12 KiB) Viewed 8267 times
20180928_140952 (Medium).jpg (319.1 KiB) Viewed 8267 times
20180928_122104 (Medium).jpg (373.77 KiB) Viewed 8267 times
I also added a strong piece of angle Iron which bolted in the sill, this bolted in place of the original tin piece so no extra holes were needed...
20180905_132240 (Medium).jpg (192.41 KiB) Viewed 8267 times
I then preceded to remove the rear facia and a few other bits and then at 7.50am this morning (Saturday) i had a visitor ...
20180929_081950 (Medium).jpg (266.23 KiB) Viewed 8267 times
I'l continue how we got in, in the next post ... ;)
Re: MEC'S EPIC RESTORATION
Postby mec » Sat Sep 29, 2018 9:18 pm
So Mr Alex Denny arrived and we got to work ...
20180929_101826 (Medium).jpg (328.77 KiB) Viewed 8259 times
20180929_120555 (Medium).jpg (300.7 KiB) Viewed 8259 times
20180929_122810 (Medium).jpg (236.58 KiB) Viewed 8259 times
20180929_124241 (Medium).jpg (325.79 KiB) Viewed 8259 times
CLICK ON THE LINK BELOW TO SEE A VIDEO FROM TODAY
https://www.flickr.com/photos/157357395@N04/shares/717aXh
20180929_130621 (Medium).jpg (353.61 KiB) Viewed 8259 times
20180929_130637 (Medium).jpg (312.93 KiB) Viewed 8259 times
20180929_130648 (Medium).jpg (236.88 KiB) Viewed 8259 times
20180929_130655 (Medium).jpg (269.94 KiB) Viewed 8259 times
20180929_130715 (Medium).jpg (279.48 KiB) Viewed 8259 times
Engine out ...
20180929_152312 (Medium).jpg (370.18 KiB) Viewed 8259 times
Gearbox out ..
20180929_180249 (Medium).jpg (287.27 KiB) Viewed 8259 times
As its sits tonight...
20180929_190532 (Medium).jpg (303.7 KiB) Viewed 8259 times
Not Bad for 8 Odd Hours work ... more updates to come soon ! watch this space :dmcdoors:
Postby MikeWard » Sat Sep 29, 2018 11:18 pm
:o Nice work, keep the updates coming!
Postby Admin-bloke » Sun Sep 30, 2018 8:28 am
Fantastic :thumbsup: :dmcdoors:
Postby priesh » Sun Sep 30, 2018 1:00 pm
Very nice! Great use of your space
priesh
VIN #: 1373
Postby mec » Sun Sep 30, 2018 3:25 pm
Thanks Guys, i'l have some more pics for you later ;)
Postby Domi » Sun Sep 30, 2018 3:32 pm
Awesome job, congratulation!
Can't wait to see what's next
Postby andyd » Sun Sep 30, 2018 8:53 pm
All credit to you mec, thats top work!
Postby Dan 6511 » Sun Sep 30, 2018 9:01 pm
Superb work there mec, can't wait to see this project progressing! :D Just got to get it done in time for Hamburg ;)
Postby mec » Mon Oct 01, 2018 12:33 am
Thanks Guys, its a very daunting thing to do but it has to be done, Alex's help yesterday was invaluable as he's already done 2 !
So then onto today (Sunday), another full day in the garage (on my own this time) and progress carried on at a fair pace...
20180930_101042 (Medium).jpg (303.2 KiB) Viewed 8187 times
20180930_111420 (Medium).jpg (311.9 KiB) Viewed 8187 times
Tank and Rads off
20180930_112701 (Medium).jpg (335.69 KiB) Viewed 8187 times
Going up !
20180930_122358 (Medium).jpg (292.61 KiB) Viewed 8187 times
20180930_122337 (Medium).jpg (326.79 KiB) Viewed 8187 times
20180930_123829 (Medium).jpg (310.79 KiB) Viewed 8187 times
Rear suspension out
20180930_143450 (Medium).jpg (351.58 KiB) Viewed 8187 times
and then to the end of the day... chassis completely striped...
20180930_225714 (Medium).jpg (288.25 KiB) Viewed 8187 times
So how bad is the rust i hear you asking, well il let the pictures do the talking :shock:
20180930_225755 (Medium).jpg (234.16 KiB) Viewed 8187 times
20180930_225801 (Medium).jpg (184.45 KiB) Viewed 8187 times
20180930_225807 (Medium).jpg (304.66 KiB) Viewed 8187 times
20180930_225814 (Medium).jpg (255.68 KiB) Viewed 8187 times
20180930_225822 (Medium).jpg (207.31 KiB) Viewed 8187 times
20180930_225915 (Medium).jpg (220.54 KiB) Viewed 8187 times
20180930_225927 (Medium).jpg (244.12 KiB) Viewed 8187 times
20180930_225943 (Medium).jpg (216.98 KiB) Viewed 8187 times
20180930_225948 (Medium).jpg (212.19 KiB) Viewed 8187 times
20180930_225958 (Medium).jpg (242.65 KiB) Viewed 8187 times
All of the pictures above were with the chassis up the right way, then i turned it over :o
20180930_230142 (Medium).jpg (314.26 KiB) Viewed 8187 times
This black area at the front i think is infact one massive plate that been welded on ...
20180930_230120 (Medium).jpg (330.27 KiB) Viewed 8187 times
20180930_230204 (Medium).jpg (240.1 KiB) Viewed 8187 times
20180930_230213 (Medium).jpg (259.07 KiB) Viewed 8187 times
20180930_230216 (Medium).jpg (294.13 KiB) Viewed 8187 times
20180930_230301 (Medium).jpg (229.95 KiB) Viewed 8187 times
20180930_230522 (Medium).jpg (298.9 KiB) Viewed 8187 times
So there you have it, my delorean stripped to a bare chassis in 2 days... looks like that was the easy bit !
Lets hope the genius welding of Mr Alex Denny can save my car, 1st though is a phone call in the morning to get the chassis booked in for dipping to strip all the rubbish off and see whats left !!
