MEC'S EPIC RESTORATION
Re: MEC'S EPIC RESTORATION
Postby Dan 6511 » Mon Oct 01, 2018 8:56 am
Awesome work mec, and the chassis looks a lot worse than I was expecting and definitely in need of doing, no doubt about that.
Postby DJK73 » Mon Oct 01, 2018 12:15 pm
This is Awesome Mec , cant wait to see the progress
Dbro4
Ex Vin#10223
Grey interior, Manual
Free flow
DJK73
VIN #: 10223
Postby carl hammond » Mon Oct 01, 2018 2:33 pm
TOP work MEC! :thumbsup: :D
Looks like you caught it in time! :shock:
Looking forward to seeing the restoration! Alex is a legend! :jzd:
Postby cis6409 » Mon Oct 01, 2018 2:51 pm
Fantastic stuff mec best of luck with it, love the ingenious solution with the body lift.! .
Looking forward to the rest of it
Postby mknowlton » Mon Oct 01, 2018 4:32 pm
Well done Guys, that's an awesome job that you are doing there!
Mike Knowlton (DBro 1)
DeLorean DMC-12, VIN#4208,
mknowlton
VIN #: 04208
Postby jerzybondov » Mon Oct 01, 2018 8:23 pm
Mec, this is indeed totally epic!! Awesome getting all that done in 2 days. How long did it take to build the DeLorean Lifting System (TM)?
Dan - how did you lift your body up when you did yours on your drive? I just remember you replacing the chassis with bricks but not actually how you got the body off...
Postby Chris Hawes » Mon Oct 01, 2018 8:56 pm
Awesome progress, you're in good hands with the talented Alex!
So what's the plan after the dipping and welding?
Galvanising so that it can get into all the boxed off areas?
Regards,
Chris Hawes
Chris Hawes
VIN #: Ex owner of 5255
Postby Kenny » Mon Oct 01, 2018 9:37 pm
Excellent work
I see the same rust issues in my future. Where are you sending the frame for stripping?
Kenny
VIN #: 1569
Postby Dan 6511 » Mon Oct 01, 2018 10:06 pm
jerzybondov wrote:Dan - how did you lift your body up when you did yours on your drive? I just remember you replacing the chassis with bricks but not actually how you got the body off...
I took it off with bricks too. Jacked it up, put a brick in, jacked again, another brick in etc. Then when high enough I moved the bricks out to clear the wheels and put wooden beams across. Lots of messing around compared to Mec's lifting solution!
body off.jpg (121.31 KiB) Viewed 4030 times
Postby TristanC » Mon Oct 01, 2018 11:05 pm
WOW !
Well done Mec - that’s brilliant work there!
Looking forward to following this thread.
Tris
Tristan J Carroll
#11477 Jan '82 Grey Manual
TristanC
VIN #: 11477
