Performance air intake
Postby Spudmurphy » Thu Mar 09, 2017 7:27 pm
I was just wondering on one of these to replace the rusty looking stock intake
http://www.deloreanclub.uk/performance-air-intake.html
does anybody have a picture of what the actual installation looks like please?
Re: Performance air intake
Postby gary290 » Thu Mar 09, 2017 7:57 pm
The rusty pipe is a hot air transfer pipe from the the top of the exhaust manifold to the intake pipe, in cold parts of the world it helps get the engine going a bit better, the black box is a type of valve that opens and closes depending on the temp, if you don't use the car in a cold part of the word get rid of it and replace with the part listed, i only use my car in summer so i don't need it, if know one else puts up a pic i'll do it tonight
gary290
VIN #: 17005
Postby Spudmurphy » Thu Mar 09, 2017 8:41 pm
Great stuff thanks gary.
Postby arranj » Thu Mar 09, 2017 9:27 pm
Couple of random pics - couple of slightly different angle solutions here. As Gary says, it is only very cold, like northern Sweden cold. Something that came over with the Volvo - the part you'd be ripping out actually has "Volvo" stamped on it.
Postby eric » Fri Nov 02, 2018 5:25 pm
What do I do with the other end of the rusty pipe ? just remove totally and leave a hole.... This explains why I had so much trouble trying to fit with the existing fitting in line :)
Postby arranj » Fri Nov 02, 2018 5:38 pm
The metal "hole" on the engine you mean? That's the "stove" which is basically just a piece of metal screwed on, with a hole (that doesn't go anywhere) in it. Just 2 screws and remove it. Or leave it there.
Postby MikeWard » Fri Nov 02, 2018 5:58 pm
eric wrote:What do I do with the other end of the rusty pipe ? just remove totally and leave a hole.... This explains why I had so much trouble trying to fit with the existing fitting in line :)
Remove everything you see here.
OE air intake.jpg (401.8 KiB) Viewed 5030 times
Postby eric » Fri Nov 02, 2018 7:28 pm
Super thanks, quite a space saving :)
Postby TristanC » Sat Nov 03, 2018 11:21 am
I’ve been thinking about this too.
Thanks for asking the question Kevin, and thanks Mike W for showing what to remove :)
Happy days. I’ll be doing this soon.
Tris
Tristan J Carroll
#11477 Jan '82 Grey Manual
TristanC
VIN #: 11477
Postby Spudmurphy » Sun Nov 04, 2018 1:34 am
I bought the new hose from Ed - well I was in Amsterdam anyway so why not ? :-)
I ended up buying an aluminium Air intake cone from Ash silicone hoses and bonded it in with some wurth bond. I later made some sexy SS bands for Ed's hose and it's looking good.
This is an old pic with the old coolant bottle ... but you can see the cone.
ali cone.jpg (93.1 KiB) Viewed 4979 times
