Postby A Van » Fri May 10, 2019 9:39 pm
Can’t help on those wires .. been a while since I have been in that area
Are the reinforcing plates too thick?
Postby gruffalo » Sat May 11, 2019 2:43 pm
After som grinding and taking it on and off 5 times, the front bumper fits with no issues.
Postby cis6409 » Sat May 11, 2019 2:54 pm
The small cylindrical wire connectors are the bonnet light connections
Postby cis6409 » Sat May 11, 2019 3:14 pm
The 3 pin plug is for the Amber front running lights and indicators
Postby gruffalo » Fri May 17, 2019 11:00 am
I have hood alignment and panel gap issues...
Corner
Middle
Corner
Postby andyd » Fri May 17, 2019 11:49 am
Probably fairly standard. Does the bonnet catch the fascia when it opens?
If not, I dont think that's too severe?
Postby dmc4087 » Fri May 17, 2019 1:31 pm
I hand to grind down part of the front wings (the recessed part hidden by the fascia) where they bolt to the tub - they were fouling on the fascia, causing them to sit on the corners a little like your pic above.
If you remove the fascia you might see marks underneath where the stainless is rubbing.
They are a bit of a bollocks though. I think they shrink over time and there isn't much that can be done about it?
Postby gruffalo » Fri May 17, 2019 2:41 pm
I'm more concerned with the curve of the hood not matching that of the bumper.
Postby bandit » Fri May 17, 2019 8:49 pm
If you can’t throw a cat between the panels then they are too close & not Delorean spec ;)
Postby gruffalo » Mon Jun 03, 2019 10:29 pm
Well, I got the heater back in, along with the dashboard and instrument binnacle. Slow but steady getting there.
