A friend has recently purchased a Renault Alpine believed to be one of the several cars used by DeLorean as an engine mule. It is running the 2.7 engine and non lambda fuel injection also has the Volvo auxiliary air valve instead of the idle speed motor. The airbox is virtually identical to the DeLorean although looks almost handmade, the sump etc is all DeLorean too.
The accumulator is a lot easier to get to
It is running although has been sat around for a while so in need of quite a lot of work but the engine is running better now it’s been run a while.
Anyway some pictures for anyone interested.
- IMG_1605.jpg (398.81 KiB) Viewed 4983 times
- IMG_1598.jpg (445.29 KiB) Viewed 4983 times
- IMG_1611.jpg (952.67 KiB) Viewed 4983 times
- cb470a0b-c271-49fa-87cb-3c714b43f3e3.jpg (409.38 KiB) Viewed 4983 times
