by Dan 6511 » Tue Mar 17, 2020 3:25 pm
cis6409 wrote:Was wondering do you need to use rtv or similar on the end caps when putting them back on to the joint itself to help seal it or do without?
I didn't on my original D and they leaked grease and had to be re-done, so I did on this one and they have been spot on, but you will need to make sure the surfaces are very clean.
They had blue sealant on them from the factory, you'll probably find some residue of this left behind?
This was mine. I masked off the surface when putting the grease in so they were nice and clean to put on a thin smear of sealant:
- Masked.jpg (117.56 KiB) Viewed 4480 times
- CV.jpg (86.4 KiB) Viewed 4480 times
