Project "Plonker"
Re: Project "Plonker"
Postby mec » Fri Mar 06, 2020 4:30 am
Thanks mate that was what i was going for, the explodaview type pic,
I know maybe the repairs don't look that neat from the front atm, but I'm getting all the strength back in the body 1st so i can work on the finishing after without it flexing, well thats the plan :? ;)
Postby mec » Sat Apr 04, 2020 7:30 pm
Hi all, hope everyone is well and safe in this crazy situation we find ourselves in, as you would imagine I have taken full advantage of the situation and spent quite a bit of time in the garage working on Project Plonker !
So il carry on where the last post left off...
Shortly after we got back from our Norfolk meet, i decided to do something with the saloon, I had a deal going with a guy local to me in Chelmsford who deals in Regal parts, he wanted a regal front end cut above the windscreen to turn into a photo booth for the Only fools and horses shows he does,
(he was trying to buy the saloon off the guy i got it from but i beat him to it) so i did a deal with him for my front end cut above the screen for another front end cut below the screen and some parts my way ...
20200318_203351 (Medium).jpg (179.92 KiB) Viewed 8970 times
20200318_205034 (Medium).jpg (166.88 KiB) Viewed 8970 times
20200318_205023 (Medium).jpg (219.35 KiB) Viewed 8970 times
I must add i DIDNT want to do this !! but needs must
Before the Front end went, i had to cut off the inner air vent section which i need for the van
20200318_212157 (Medium).jpg (183.45 KiB) Viewed 8970 times
I then cut off the rear bumper section off the saloon shell which i need for the van, this is pretty much identical barring the number plate light mount in the centre and also the saloon rear bumper is not as deep, but the way i cut it off, i included part of the inner bumper so this made it deep enough to use on the van..
20200320_154128 (Medium).jpg (195.7 KiB) Viewed 8970 times
20200320_154135 (Medium).jpg (222.08 KiB) Viewed 8970 times
Before i could fit the rear bumper i had to repair another area of the rear floor area, this is the area in the following pic under the furthest metal brace in...
20200319_131953 (Medium).jpg (199.73 KiB) Viewed 8970 times
from underneath ...
20200319_144009 (Medium).jpg (253 KiB) Viewed 8970 times
I also put extra renforcement on the lip of the floor...
20200320_092258 (Medium).jpg (127.76 KiB) Viewed 8970 times
I then repaired the passenger side lower side panel...
20200320_113550 (Medium).jpg (134.79 KiB) Viewed 8970 times
20200320_113556 (Medium).jpg (175.69 KiB) Viewed 8970 times
20200320_120307 (Medium).jpg (194.35 KiB) Viewed 8970 times
20200320_133317 (Medium).jpg (306.42 KiB) Viewed 8970 times
20200320_145800 (Medium).jpg (184.35 KiB) Viewed 8970 times
I then jumped to the drivers front floor, this needed a repair which i wanted to get done so i could get the shell of the 2 tressels it was perched on and onto a custom made frame on wheels so it can be moved around, heres the floor...
20200321_155713 (Medium).jpg (201.48 KiB) Viewed 8970 times
20200321_170043 (Medium).jpg (206.1 KiB) Viewed 8970 times
Heres the frame ...
20200323_133532 (Medium).jpg (270.59 KiB) Viewed 8970 times
20200323_153827 (Medium).jpg (211.23 KiB) Viewed 8970 times
So then back to the rear bumper, now the shell is on the frame its much easier to manouver to get to the different areas, 1st off, i glued the rear bumper onto the floor lip...
20200325_122951 (Medium).jpg (218.62 KiB) Viewed 8970 times
20200325_123109 (Medium).jpg (246.14 KiB) Viewed 8970 times
this was clamped between a piece of wood and angle iron until it set, then i started the fiberglass from underneath, the saloon bumper inner was square on the corners so i had to shape this is situ...
from this..
20200326_122721 (Medium).jpg (192.79 KiB) Viewed 8970 times
to this...
20200326_124448 (Medium).jpg (148 KiB) Viewed 8970 times
then it was all fibreglassed...
20200326_155334 (Medium).jpg (192.93 KiB) Viewed 8970 times
The corners on this were particularly hard to get level but its not to bad...
20200327_202011 (Medium).jpg (192.19 KiB) Viewed 8970 times
The rear bumper and floor area are not very very strong and just to make sure i actually sat on it and it took my 17st no problem, so when its on the chassis with the support frame underneath its not going anywhere.
I then moved onto a sill repair on the drivers side ...
20200328_163115 (Medium).jpg (172.33 KiB) Viewed 8970 times
20200328_232353 (Medium).jpg (153.61 KiB) Viewed 8970 times
20200328_232422 (Medium).jpg (127.36 KiB) Viewed 8970 times
20200329_001018 (Medium).jpg (160.89 KiB) Viewed 8970 times
I will carry on in the next post as i have run out of pictures on this one... to be continued .....
Postby mec » Sat Apr 04, 2020 8:27 pm
So carrying on from the last post, after the sill repair i did another front drivers side panel repair and also a battery and foot well repair...
20200328_232427 (Medium).jpg (114.63 KiB) Viewed 8967 times
20200328_232514 (Medium).jpg (152.67 KiB) Viewed 8967 times
20200329_000317 (Medium).jpg (154.04 KiB) Viewed 8967 times
20200329_003512 (Medium).jpg (191.8 KiB) Viewed 8967 times
20200329_025712 (Medium).jpg (145.27 KiB) Viewed 8967 times
20200329_025746 (Medium).jpg (170.8 KiB) Viewed 8967 times
So then comes the main event... THE FRONT END :shock:
Initially i was going to put in as little as possible to maintain the front end strength, but as a lot of the damage was so close together i later decided to put the front end on as one, this would make for a neater job and less joins, first though the new front end I traded mine for needed a repair, heres the new front...
20200325_125543 (Medium).jpg (232.51 KiB) Viewed 8967 times
you can see the damage on the corner,
this was repaired 1st to make sure it was strong and the right shape...
20200331_135607 (Medium).jpg (214.38 KiB) Viewed 8967 times
20200331_152643 (Medium).jpg (231.69 KiB) Viewed 8967 times
Also before fitting the front end i had to repair the drivers side front corner of the van so its also strong and the right shape...
20200325_152245 (Medium).jpg (232.13 KiB) Viewed 8967 times
20200325_161519 (Medium).jpg (226.6 KiB) Viewed 8967 times
20200325_171442 (Medium).jpg (206.7 KiB) Viewed 8967 times
this looks a little rough atm but is very strong... so the main front ...
here are the planned cut lines ...
20200330_003317 (Medium).jpg (199.49 KiB) Viewed 8967 times
20200330_003325 (Medium).jpg (181.5 KiB) Viewed 8967 times
20200330_003338 (Medium).jpg (174.12 KiB) Viewed 8967 times
20200330_003347 (Medium).jpg (184.82 KiB) Viewed 8967 times
20200330_003355 (Medium).jpg (128.14 KiB) Viewed 8967 times
So a BIG deep breath and..
20200331_123806 (Medium).jpg (214.68 KiB) Viewed 8967 times
20200331_123824 (Medium).jpg (233.44 KiB) Viewed 8967 times
1ST test fit ...
20200331_182005 (Medium).jpg (240.64 KiB) Viewed 8967 times
then cut to fit ...
20200402_190310 (Medium).jpg (190.39 KiB) Viewed 8967 times
20200402_185939 (Medium).jpg (212.51 KiB) Viewed 8967 times
20200402_190319 (Medium).jpg (171.66 KiB) Viewed 8967 times
20200403_164314 (Medium).jpg (148.52 KiB) Viewed 8967 times
20200403_164442 (Medium).jpg (231 KiB) Viewed 8967 times
20200403_201303 (Medium).jpg (240.31 KiB) Viewed 8967 times
So there you have it, im really pleased with the front end, there is still some more to do but im over the hump of the fibre glass work now :dance: :dance:
Stay well everyone !!
Postby DMC1983 » Sat Apr 04, 2020 11:00 pm
Well someones been busy. Looking good and coming along nicely
Postby mec » Sat Apr 04, 2020 11:41 pm
Thanks mate, yea its definitely accelerated the project being off, glad to see you doing some on yours too !
Postby Admin-bloke » Sun Apr 05, 2020 9:30 am
Great pics Mike, it's made my day seeing project pics
Postby mec » Sun Apr 05, 2020 11:25 am
Thanks Mr T, hope you are getting a bit of garage time around your busy work schedule :kiss:
Postby Admin-bloke » Sun Apr 05, 2020 2:14 pm
mec wrote:Thanks Mr T, hope you are getting a bit of garage time around your busy work schedule :kiss:
I've done more in the last 3 hours tidying the garage up than I have in the last year. I can almost get to the D now...!
Postby bandit » Sun Apr 05, 2020 4:38 pm
Wow mec, top work young man. I liked the bit where you said you sat on the floor & it held your weight. I just had a vision of you going through with your head & massooove shoulders sticking out the top. Now that would have been the selfie of the year ;)
Postby mec » Sun Apr 05, 2020 8:40 pm
Brilliant work Mr T !!
Julian you really made me laugh when i read that ! :lol: :lol:
Yea that would have made a great selfie but im glad it didnt happen lol :dance: :dance:
