Back to the chassis again.. With the front and rear inner 'y' doubler plates removed and cleaned out the chassis could go back to the blasters again to get everything cleaned up and ready again for re glavanising.
All the separate parts were numbered and listed so they could go back on for final welding. Then all going well onto the galvanisers.
First up was a mock up again to make sure all the major components lined up and fitted as they should and see if anything else needed doing..
All 34 pieces listed
She s looking alot cleaner now this time. Now hopefully a straight run welding everything back up and finally off to the glavanisers.. That's the plan anyways..
An eagle eye spot from Nicky saw an extra little spot of rust was hiding under the passenger side base of the rear cradle under the double lipped skin. A previous repair on a repair I think was done here but either way not very well. So off with it..
Forgot to take a pic of it fully finished before closing it up
