Delorean wheel repair
Postby Dan 6511 » Thu Jan 28, 2010 8:01 pm
Today I took my 2 damaged Delorean wheels to be repaired. Here is a photo of my wheel on the machine, and a video of how they do it. Its amazing how flexible the wheels are. The man also commented on how soft the delorean rims are compared to most cars, he also commented on the hole in the center not being machined very accurately either compared to other wheels!! Yet another example of delorean craftsmanship lol. Anyway they are circle shaped again now and balanced. :)
Re: Delorean wheel repair
Postby RobvdVeer » Thu Jan 28, 2010 11:03 pm
Nice one Dan. Was it expensive?
Postby Dan 6511 » Thu Jan 28, 2010 11:28 pm
£60 for 2 wheels including taking tires on and off and balancing.
Postby RobvdVeer » Thu Jan 28, 2010 11:49 pm
I dont know how much your rims were warped, but that sounds like a good price compared to replacing.
Postby arranj » Thu Jan 28, 2010 11:56 pm
How did your rims become warped then?
Postby Dan 6511 » Fri Jan 29, 2010 12:11 am
Some previous owner drove down a large pot hole I suspect.
Postby Admin-bloke » Fri Jan 29, 2010 10:14 am
Wow what a machine!!!!!!
So Dan, did the car feel better after you had that lot done??
Postby bandit » Fri Jan 29, 2010 10:44 am
Dan 6457 wrote:£60 for 2 wheels including taking tires on and off and balancing.
Dan, it's tyres mate, not tires. Before you know it, you'll be telling us you caught the rim on the 'sidewalk'.
Postby RobvdVeer » Fri Jan 29, 2010 10:57 am
Tips for Proper English
1. Avoid alliteration. Always.
2. Never use a long word when a diminutive one will do.
4. Employ the vernacular.
5. Eschew ampersands & abbreviations, etc.
6. Parenthetical remarks (however relevant) are unnecessary.
7. Remember to never split an infinitive.
8. Contractions aren't necessary.
9. Foreign words and phrases are not apropos.
10. One should never generalize.
11. Eliminate quotations. As Ralph Waldo Emerson said, "I hate quotations. Tell me what you know."
12. Comparisons are as bad as cliches.
13. Don't be redundant; don't use more words than necessary; it's highly superfluous.
14. Be more or less specific.
15. Understatement is always best.
16. One-word sentences? Eliminate.
17. Analogies in writing are like feathers on a snake.
18. The passive voice is to be avoided.
19. Go around the barn at high noon to avoid colloquialisms.
20. Even if a mixed metaphor sings, it should be derailed.
21. Who needs rhetorical questions?
22. Exaggeration is a billion times worse than understatement.
23. Don't never use a double negation.
24. capitalize every sentence and remember always end it with point
25. Do not put statements in the negative form.
26. Verbs have to agree with their subjects.
27. Proofread carefully to see if you words out.
28. If you reread your work, you can find on rereading a great deal
of repetition can be avoided by rereading and editing.
29. A writer must not shift your point of view.
30. And don't start a sentence with a conjunction. (Remember, too, a preposition is a terrible word to end a sentence with.)
31. Don't overuse exclamation marks!!
32. Place pronouns as close as possible, especially in long sentences,
as of 10 or more words, to their antecedents.
33. Writing carefully, dangling participles must be avoided.
34. If any word is improper at the end of a sentence, a linking verb is.
35. Take the bull by the hand and avoid mixing metaphors.
36. Avoid trendy locutions that sound flaky.
37. Everyone should be careful to use a singular pronoun with singular nouns in their writing.
38. Always pick on the correct idiom.
39. The adverb always follows the verb.
40. Last but not least, avoid cliches like the plague;
They're old hat; seek viable alternatives.
Other Versions:
1.Don't abbrev.
2.Check to see if you any words out.
3.Be carefully to use adjectives and adverbs correct.
4.About sentence fragments.
5.When dangling, don't use participles.
6.Don't use no double negatives.
7.Each pronoun agrees with their antecedent.
8.Just between you and I, case is important.
9.Join clauses good, like a conjunction should.
10.Don't use commas, that aren't necessary.
11.Its important to use apostrophe's right.
12.It's better not to unnecessarily split an infinitive.
13.Never leave a transitive verb just lay there without an object.
14.Only Proper Nouns should be capitalized. also a sentence should begin with a capital and end with a period
15.Use hyphens in compound-words, not just in any two-word phrase.
16.In letters compositions reports and things like that we use commas
to keep a string of items apart.
17.Watch out for irregular verbs which have creeped into our language.
18.Verbs has to agree with their subjects.
19.Avoid unnecessary redundancy.
20.A writer mustn't shift your point of view.
21.Don't write a run-on sentence you've got to punctuate it.
22.A preposition isn't a good thing to end a sentence with.
23.Avoid cliches like the plague.
24.It is wrong to ever split an infinitive.
25.Profanity sucks.
Postby tourettes tony » Fri Jan 29, 2010 11:27 am
nice one julian :lol: i reckon hes getting ready to skip over the other side of the pond :D TT
