#CANCELLED# - Sorting out Aaron May's Car at Eurotec 2010
Postby tourettes tony » Sun Mar 21, 2010 9:34 pm
After discussions the weekend with various members we will be sorting Aaron May's car out.
It will be done on the friday.
Spares we need:
dizzy i have a spare
rotor arm and cap
coil
spare injectors
spark plugs
leads i have
cpr
oxy sensor
idle motor or aux air valve
plenium chamber i have
any other suggestions apreciated TT and thanks to all who offered to help out :D
Re: sorting out Aaron May's car- tec at Eurotec 2010
Postby delorean12uk » Sun Mar 21, 2010 9:43 pm
Tone, spare vac hoseing, as well as tools, gazebo, tarpoline just in case of adverse weather conditions. And if we are successful in getting Aarons car working he must honour this by performing 'Rock star' on the wii, including Lyrics!!
Postby Dan 6511 » Sun Mar 21, 2010 9:44 pm
Gallon of unleaded gasoline and a box of matches.... :lol:
Postby delorean12uk » Sun Mar 21, 2010 9:51 pm
Dan 6457 wrote:Gallon of unleaded gasoline and a box of matches.... :lol:
Dan has got a point, instead of repairing Aarans car we could use it as an effigy, Aaran could still do 'Rock Star' afterwards as well
Postby Admin-bloke » Mon Mar 22, 2010 12:22 pm
I will use this post as a reminder for myself to bring:
I will bring:
Fuel pressure tester
Known working OEM CPR (Dans car)
Injector Tester (if I get to change the O rings in it)
Spare Idle ECU
Spare Ignition Amplifier (if Shane hasn't got this)
Spare Chips to repair ECU's if time permits
Various Multimeters
Wiring toolbox with loads of electrical crimp stuff...
Spare fuel hoses
Spare Relays
Spare inline fuse holders inc fuses etc....
If others could bring spare O rings for fuel distributor, spare working fuel ecu, loads of copper washers for the K-Jet that would be a start !
Postby bozzzydmc » Mon Mar 22, 2010 9:24 pm
Sure im up for helping out here ...
Bearing in mind Ed U is coming perhaps he can bring over any other bits we need such as O Rings and copper washers etc
Postby hana 5284 » Mon Mar 22, 2010 9:41 pm
i have a box of various rubber o rings all sizes i will bring
Postby bozzzydmc » Mon Mar 22, 2010 9:43 pm
Eh up Tys ... just make sure they are suitable for unleaded fuel eh x
Postby hana 5284 » Mon Mar 22, 2010 10:41 pm
bozzy dont ask me tec question like that i think they are i will look and let you know.
just a thought though if aaron hasnt run the car for a couple of years will the fuel be any good or should he empty it out and refill it before he gets there in june.
Postby bozzzydmc » Mon Mar 22, 2010 10:52 pm
Oooh ... he needs to def hand pump it all out before he tries to start it ...
Then clean out the tank and fill it with some fresh stuff
Hope he checks this thread out before he tries starting it
bozzzy
