Postby RobvdVeer » Thu Mar 19, 2015 12:53 pm
Not daily, no, granted..
Postby A Van » Thu Mar 19, 2015 4:05 pm
ALEXAKOS wrote:
RobvdVeer wrote:Nah. I've seen enough of it. :)
Never with Greek txt wraparound and a price on the cover :)
Hahha! Funny replies guys
Postby ALEXAKOS » Thu Mar 19, 2015 4:11 pm
Yay,
We're a jerky lot;)
Postby ALEXAKOS » Thu Mar 19, 2015 7:57 pm
Finally got the courtesy LEDs working.
Postby ALEXAKOS » Fri Mar 27, 2015 2:20 pm
Onwards picking up tiny left over jobs
Another problematic DMCH part. The inner door seals.
Even with constant silicone lubbing, realigning and care, they just tore after about 40 opening and closing the doors, they tore up on both sides at the exact same place. On the upper front corners. Those are too damn big if you ask me and the pressure on the doors closing were always too tight.
So I got a set for half as much one size smaller.
Fits perfectly, seals just great and let's the door close smoothly.
I finally my A/C is done with 134a cooling fluid.
Works perfectly and will give me a cool head in the summer.
Last job, I got rid of the upper engine louvre seals and replaced them with a rather softer seal.
Grips nicely on the provided rear fender lips and let's the louvre sit softly when closed.
First I cleaned the lips
Then cut out the damper bases
And clipped on
This is what the resting of the louvre looks like
Postby MikeWard » Fri Mar 27, 2015 3:13 pm
Hi Alex,
Would you be able to share the links for the inner door seals you found, and also for the louvre seals?
Cheers, Mike
Postby ALEXAKOS » Fri Mar 27, 2015 3:30 pm
Not really mike.
I bought them out of a store in Athens that sells seals by the meter and also struts! 7€ per meter cost. I am looking to exchange my door struts with custom ones they sell there. They make them per kilo of weight to be supported. My ebay struts really are too weak for the doors. On cold days they need help to be lifted all the way :(
Postby ALEXAKOS » Fri Mar 27, 2015 3:32 pm
MikeWard wrote:Hi Alex,
Cheers, Mike
On a second note I'd like Al to give us the link for the inner door seals he got for the black beast. I think those are THE BEST ever seals I have seen on the Delo
Postby MikeWard » Fri Mar 27, 2015 3:47 pm
No worries Alex.
I agree, the seals Al found for his car look like they fit perfectly!
ALEXAKOS wrote:On cold days they need help to be lifted all the way :(
You have cold days in Greece?
Postby ALEXAKOS » Fri Mar 27, 2015 3:49 pm
Not really. Least would be 5 C, and even then the struts are too weak:(
