Postby arranj » Thu Apr 15, 2010 10:12 pm
cineman wrote:good to see you went on with the works :mrgreen:
I got my frame back a pair of day ago.
Wow cineman! That looks like a new frame! :shock:
Postby mnickels » Fri Apr 16, 2010 11:17 am
Chassis will be ready Tuesday :(
Ireland Rep
mnickels
VIN #: 2456
Postby delorean12uk » Fri Apr 16, 2010 3:17 pm
May I ask the benefits of the Lower Control arm support???
Postby DeLorean Cars » Fri Apr 16, 2010 5:15 pm
That's a loaded question!
It transfers some of the forces that would normally be passed to the anti roll bar (when the wheel is "dragged" by braking or bumps) to the main lower pivot. It's for improving the handling. We had a huge discussion on this on DMCTalk and I'm not convinced. It's kind of trying to make the lower arm into a wishbone without eliminitaing the problem of the lower arm tracking the end of the anti roll bar.... "treating the symptoms and not the disease". Everyone who has fitted them likes them, but it's interesting to know that they hit the shock tower if you drive like Andrea.
DeLorean Cars
VIN #: 4772, 3352
Postby mnickels » Wed Apr 21, 2010 7:34 pm
Good and bad day
Ireland Rep
mnickels
VIN #: 2456
Postby bozzzydmc » Wed Apr 21, 2010 7:36 pm
Matt !!! :(
WTF has happened to that ????
Postby RobvdVeer » Wed Apr 21, 2010 7:40 pm
Matt,
Sorry to see that bent bit, but otherwise that frame looks stunning! i've been having a POS-attack these last days so i'm glad to see something nice.
Postby mnickels » Wed Apr 21, 2010 7:42 pm
bozzzydmc wrote:Matt !!! :(
The heat while galvanising :( 3 out of the 4 are straight. Can't believe it
Cheers Rob
Ireland Rep
mnickels
VIN #: 2456
Postby Dan 6511 » Wed Apr 21, 2010 8:06 pm
No way did the heat do that!! They are making an excuse i think. More like the strap to lower it into the tank was pulled tight or it was dropped on something.
Postby mnickels » Wed Apr 21, 2010 8:09 pm
Well it's done now and lucky it isn't a really obvious place. I 'll have to straighten it best I can and touch it up
Ireland Rep
mnickels
VIN #: 2456
