Project 3193
Re: Project 3193
Postby InoX » Tue Jun 01, 2010 8:24 pm
new fuse box install got finished on the weekend. got in a bit of a pickle with 10 and 11. same colour wires and i took both labels off which told me which was which. I think I've sorted it :)
You'll notice that the box is on the loom, but the loom is out of the compartment. I'm having to pull the metal bracket out to have it powdercoated.
does anyone know where i can get the washers/spacers/reinforcers that the seats bolt into? mine are corroded:
might have to get a couple of stainless washers and tiger seal them in place or lay some resin down.
cheers!
Trying desperately to maintain my enthusiasm. :lol:
InoX
Re: Project 3193
Postby RobvdVeer » Tue Jun 01, 2010 8:35 pm
InoX wrote:Trying desperately to maintain my enthusiasm. :lol:
You're doing great, so keep it up! I've seen you do things I need to put on my list as well, so thank you for that... :lol:
Re: Project 3193
Postby InoX » Tue Jun 01, 2010 9:06 pm
cheers mate. :)
just ordered dynomat. I can get the interior straightened out and start laying that stuff next.
should make the beast look tidier at least.
InoX
Re: Project 3193
Postby A Van » Tue Jun 01, 2010 9:08 pm
Stonkingly good work Dave, please keep it up.
Re: Project 3193
Postby Dan 6511 » Sun Jun 06, 2010 10:08 pm
Hi Dave, if you can get the measurements of the spacers I can make you some up on the Lathe :)
Re: Project 3193
Postby InoX » Sun Jun 06, 2010 10:29 pm
hmmm. lathe........ ;)
I've called it a night tonight. tired of pealing, scraping and sanding glue off the fibreglass. :(
going to see if i can find a non corroded spacer tomorrow under all this crap.
thanks Dan :) weeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee
it'll probably be something like this:
is this possible?
I'll then be able to just press/clamp the two together and seal with resin/PU
cheers!
InoX
Re: Project 3193
Postby Dan 6511 » Mon Jun 07, 2010 8:29 am
Yeah that's easy enough to make
Re: Project 3193
Postby InoX » Mon Jun 07, 2010 7:40 pm
hi
I've added in dimensions.
is this OK?what were you going to make it out of 304 or Alu?
let me know how much you want for a set of 8.
thanks for your help.
Dave.
InoX
Re: Project 3193
Postby Dan 6511 » Mon Jun 07, 2010 7:48 pm
I'll have to check what stock I have. I'd use either ally or stainless but would steel be ok if zinked?
Re: Project 3193
Postby InoX » Tue Jun 08, 2010 6:12 am
aye. cheers!
I've got parts to be sent to the platers anyway. cheers.
InoX
