DeLorean Cars wrote:I had an idea some time ago about "pop-up" lights that are actually mirrors reflecting a light that faces upwards from under the bonnet/front end - the light would then appear to exist somewhere behind the pop-up housing, which would be a really funky illusion. The housing would weigh very little so the pop-up mech could be made to work very fast. There's prolly some law about the beam from a headlight having to be direct though.
I reckon the biggest problem would be the "beam width". You'd either need the bulb to be very very close to the mirror, or you'd need a bigger mirror than a normal light - if you know what I mean
- Standard headlights have a distance of a few mm between the reflective surface and the bulb, so that the light "spreads" fairly evenly.
