#FINISHED - Eurotec Rolling Road Friday 24th June
Re: SPECIAL OFFER - Eurotec Rolling Road Friday 24th June
Postby arranj » Tue Jun 21, 2011 6:02 pm
As I understand it, the point of the RR is to get the engine running right. For emissions you need a gas analyser, which Dan is bringing. Although they do shove something up the exhaust on the dyno, so maybe that does it as well? If you go on you will get the chance to test it, make some adjustments, and test again - assuming you get here early enough.
Postby RobvdVeer » Tue Jun 21, 2011 6:05 pm
Certainly thursday would be early enough? Or do we need to skip breakfast to get on?
Postby arranj » Tue Jun 21, 2011 6:08 pm
That was aimed at Mec. He is one of the few who arrive on Friday.
Postby A Van » Tue Jun 21, 2011 8:47 pm
It will tell you fuel to air ratio as well, admin can interpret the figures and tell you where the problem is
Postby Dan 6511 » Tue Jun 21, 2011 9:07 pm
Yes I would like the pipe up the exhaust too to measure my AFR. If the rolling road that we have doesn't have this facility then I'm not really interested in going on it. I want to make sure my mixture stays ok through the rev range and isn't leaning out dangerously at high revs. I'm getting 30mpg so I'm wondering if its too lean at high revs... although the spark plugs are a good colour so maybe its just running really well. The rolling road will prove it though :)
Postby arranj » Tue Jun 21, 2011 9:10 pm
Yes - that is a pipe up the exhaust! :) - same as last year!
Postby Admin-bloke » Tue Jun 21, 2011 9:32 pm
That was an air to fuel ratio meter :)
Dan I am sure your car will be fine the amount of work you have put in it :)
Postby RobvdVeer » Tue Jun 21, 2011 9:33 pm
I just spotted the mighty Carl
Postby A Van » Tue Jun 21, 2011 9:56 pm
It was the AFR which highlighted the fault with Gez car
Postby Dan 6511 » Tue Jun 21, 2011 11:14 pm
Cool. I'm sure it will be fine, just nice to be able to see what its actually doing.... plus I need to beat Gez's car ;)
