Dangermouse wrote:Wow, that cleaned up nicely!
The mighty power of OXI-action Dermot!
And 100 bar Max. Flow Rate : 350 l/h Max. of spraying water!!!!
On to the evening news...
And and submerged into my darker quarters.
The Garage and the workshop at the bench.
Painted the D's top with a special antitrust frame paint first layer. (Sorry No pics...forgot but will catch up the day after tomorrow)
Then placed the front upper arm bushings I got from Josh @ DPI..
Everybody was curious how I would go about this job?
Well... I supposed this is a first for everybody in here eh?
Looking good?
Now you'll get to see the arms after the sand blasting and power coating job. Not Stock colors but I love it.
How?
Ok. I just used my bench's clamp.
With a bit of lube and slowly working it into position. In the one side I covered the clamp's surface with a cardboard to avoid the "injury" of the bushing and on the other side I used a cylinder with a cloth to allow the metal side of the bushing to protrude.
But... WHERE IS THAT CYLINDER FROM?
It is none other than the front wheel's bearing Shel.
On to cleaning out the steering rack.
That too has been powder painted
Again a quick reminder of the past situation:
Upper arm
Upper arm
Steering rack
