CAT Bypass Pipe
CAT Bypass Pipe
Postby flux3d » Sat Oct 12, 2013 11:19 am
I'm looking to remove the CAT on 10719 and put in a bypass pipe. Question is where do I get one of these? DMC europe used to do them, but no longer it would seem. Any ideas?
Oh, and will removing the CAT cause any problems with the MOT. I know it will release some much needed horses, plus improve the sounds of the exhaust, which will be a a plus :D Anyone done this?
On a side note my car has the original CAT and heat shield. Maybe someone might be interested in those or a swap?
Mark Sutton
New owner of VIN 10719
flux3d
VIN #: 10719
Re: CAT Bypass Pipe
Postby Admin-bloke » Sat Oct 12, 2013 1:29 pm
I've got a cat bypass. Never had a problem with not having one for the mot!
Re: CAT Bypass Pipe
Postby dannyj75 » Sun Nov 03, 2013 12:11 am
Did you manage to source a bypass pipe and gasket? If so where from and how much?
I am thinking of doing the same to vin 3320.
Does anyone have any comments about effects on mpg and hp?
Love to hear some thoughts.
dannyj75
VIN #: 3320
Re: CAT Bypass Pipe
Postby Darren C » Sun Nov 03, 2013 11:47 am
From a previous post of mine.......
Here’s some bed time reading (the MOT Testers guide from VOSA for the changes in 2012.)
http://mottesters.co.uk/files/special%2 ... Manual.pdf
To save your eyes bleeding and your brains exploding this is what you need to know.
Section 7.1, note 3:
“on vehicles that qualify for a full CAT emissions test, check for the presence of a Catalytic converter”
The key words here are “that qualify for a full CAT emissions test”
Refer to:
Section 7.3, page 2, para 4:
“Early catalyst equipped vehicles may not require a CAT test.”
Ok still with me….
Section 7.3, page 4, sub section “CAT Test” para 1:
“The catalyst test is part of MOT test for most spark ignition petrol engined vehicles first used on or after 1st August 1992.”
Eureka.
Delorean before 01/08/1992 = No CAT Test.
Delorean does not qualify for CAT emissions test, therefore presence of CAT is not part of check.
Re: CAT Bypass Pipe
Postby RobvdVeer » Sun Nov 03, 2013 12:10 pm
Great.
Re: CAT Bypass Pipe
Postby dannyj75 » Tue Apr 15, 2014 10:28 pm
I am going to a place to get a bypass for my cat made tomorrow. I will let you know what the company say and the price. For those that are interested.
DJ
dannyj75
VIN #: 3320
Re: CAT Bypass Pipe
Postby flux3d » Tue Apr 15, 2014 10:59 pm
i'd be very interested. There was talk on the other forum of getting one made. I was going to take my car over but its not taxed yet (plus half the engine is out of it while I sort the VOD).
Mark
Mark Sutton
flux3d
VIN #: 10719
Re: CAT Bypass Pipe
Postby dannyj75 » Thu Apr 24, 2014 11:40 pm
So cat bypass pipe made and installed tonight.
The company take the existing cat and put it in a jig, they then cut out the cat and weld in stainless pipe. They also replaced the studs with bolts which was needed as all the original studs sheered off when removing.
The cost was a bit steep £120 cash, but i did keep the cat and will get some money back when i scrap it.
The pipe fitted fine and the exhaust went back on smoothly.
Power improvement is hard to tell in the short journey completed but it does feel better.
If anyone wants to do the same with their cat, i am sure that any custom exhaust centre can do the same. Problem is getting the cat out and getting it to them! However pm me if you want to use the same company, i will be happy to pass on their details.
DJ
dannyj75
VIN #: 3320
