Vin 6511 - Dan's 2nd Delorean
Postby Dan 6511 » Wed Sep 24, 2014 8:29 am
What I did was unplug the thermo switch and linked the 2 pins on the connector thinking it was just a switch. Then cranked the engine with the injector in a glass and no spray at all.
Looking on the diagram, am I right in thinking with the switch unplugged I just need to ground one of the pins, the one with the UB coloured wire....?
Assuming the injector then fires when the engine cranks it would seem I need a new thermo switch :roll:
Postby A Van » Thu Sep 25, 2014 7:35 am
Dan 6511 wrote:I still have a few left from the last lot Al. Can't make anymore though as no longer have access to a lathe where I work now :(
Tom has a lathe, could ask him to make some
Postby Admin-bloke » Thu Sep 25, 2014 10:13 am
Yes, it is NOT a switch.
Yes, disconnect the thermo time switch and link to earth the UB wire.
When you crank the engine the cold start injector should fire.
This test does not necessarily mean that the thermo time switch is not working. It only operates the cold start valve when the ambient temp is below a certain temperature. ONLY test thermo time switch with the engine cold. NOTE that if the cold start injector does operate with the thermo time switch in place, it will only operate the injector for about 3 to 7 seconds (I.e. to prevent flooding).
You could try some freezer spray on the switch, but I've not done this before, so this is just a suggestion.
Good luck, don't let the cold start valve cloud an issue of a poor start due to accumulator issues or the fuel pump relay not priming the fuel pump etc. ..
Dan 6511 wrote:What I did was unplug the thermo switch and linked the 2 pins on the connector thinking it was just a switch. Then cranked the engine with the injector in a glass and no spray at all.
Postby Dan 6511 » Thu Sep 25, 2014 1:17 pm
Thanks Nick. I'll be back on it at the weekend hopefully and will report my findings :)
Postby Admin-bloke » Thu Sep 25, 2014 1:32 pm
No problem. Don't want you spending money if you don't have to. It's my Northern tight-fisted DNA really !
Postby cis6409 » Thu Sep 25, 2014 3:06 pm
Admin-bloke wrote:I have only few set of shims courtesy of the very helpful Shane in Ireland. I did promise him that if any were used then the cost of getting them made go to him. €5 each I think.
I'll be bringing my fuel pressure gauge in Oct so you're welcome to use that.
Chris s is spot on with the cold start valve :D
Hi guys
I still have a good few shims left if anyone needs dem or u run out Nick I can pop dem over to ya in the post if you 've ran out
I think I have a few .5mm shims but most of dem are d 1mm one s as per admin bloke s specs
Postby Dan 6511 » Sun Sep 28, 2014 7:38 pm
I have bypassed the thermo switch properly now and the injector fires perfectly and it starts really easily now :) So I deffo need a new thermo switch.
I also did some stripping down inside but will post pics up tomorrow.
Postby Dan 6511 » Mon Sep 29, 2014 8:48 am
photo 5.JPG (487.2 KiB) Viewed 5269 times
photo 2.JPG (726.1 KiB) Viewed 5269 times
photo 3.JPG (494.26 KiB) Viewed 5269 times
photo 1.JPG (513.03 KiB) Viewed 5269 times
Postby ALEXAKOS » Mon Sep 29, 2014 9:22 am
Wow even the replaced seat covers ripped. Heavy farter that PO must have been. :p nice going Dan;)
Postby jerzybondov » Mon Sep 29, 2014 10:09 am
What's your plan on the binnacle and dash front Dan?
