imported from tennesse, to norfolk.. restoration begins!
Re: imported from tennesse, to norfolk.. restoration begins!
Postby Dan 6511 » Wed Apr 01, 2015 6:33 pm
I saw Gez's chassis after it was stripped and was impressed with the results. All the coating was gone even on the inside sections where you can't get to it was all clean bare steel :) Well worth the drive to Dudley in my opinion.
Postby clocktown64dd » Tue Apr 14, 2015 6:16 pm
Chassis is now underway, the front was rotten as hell. I'm fabricating a whole new front end including the cross member. Cross member is fitted I'm now just waiting on a few small bits of steel to do the front. Then once the back is played in time for the finishing! May just get it blasted then galvanised as the inner parts of the frame are literally brand new. Shame about the front!! Will post pics soon keep sting that but I will!
clocktown64dd
Postby A Van » Tue Apr 14, 2015 6:30 pm
Keep going mate
Postby Admin-bloke » Tue Apr 14, 2015 7:41 pm
If you're going to fabricate a new front end, how about you cover your costs by making a run of them and sell them on?
clocktown64dd wrote:Chassis is now underway, the front was rotten as hell. I'm fabricating a whole new front end including the cross member. Cross member is fitted I'm now just waiting on a few small bits of steel to do the front. Then once the back is played in time for the finishing! May just get it blasted then galvanised as the inner parts of the frame are literally brand new. Shame about the front!! Will post pics soon keep sting that but I will!
Postby clocktown64dd » Tue Apr 14, 2015 10:09 pm
Is there anyone out there that would like one made? It's very slightly different from the original, which is shit, I've strengthened the front part and made the whole top section much stronger and reduced the water traps, it's much stronger than the original and fully welded not "stitched" so again less water traps.
clocktown64dd
Postby Admin-bloke » Tue Apr 14, 2015 10:15 pm
As the front end was designed to crumple as a safety measure, I wonder if the designers actually designed it like that?
Postby Biff » Tue Apr 14, 2015 10:29 pm
Come on mate, pics are required!!!
We seemed to have bought our D's at about the same time from the states.
Mine's an Ex-Nevada car but needed a light resto with little jobs & things needing tidying.
Anyhow, pics........... :D
Biff
VIN #: 05127
Postby carl hammond » Wed Apr 15, 2015 5:26 pm
Restoration pics, posted on behalf of Alex :D :thumbsup:
Postby carl hammond » Wed Apr 15, 2015 5:29 pm
More...
Postby carl hammond » Wed Apr 15, 2015 5:30 pm
Latest progress... You can really start to see some of Alex's fine handy work! :thumbsup:
