Norfolk DeLorean Mini-Meet-Up 7 / 8 October 2016
Re: Norfolk DeLorean Mini-Meet-Up 7 / 8 October 2016
Postby carl hammond » Thu Oct 06, 2016 10:24 am
A Van wrote:Carl H - ignition leads and cap?
Yes, please! It wouldn't be a meet, without the obligatory reap - it's like my car knows! :D
Yes, essentially HT leads/cap/rotor arm. Maybe coil, depending on what the actual issue is with the misfire! The first lot haven't been changed since I've had the car (+9 years) so well overdue for a change anyway!
I've got a commitment Saturday morning, so will aim to join you all mid afternoon. :)
Carl
Postby DJK73 » Thu Oct 06, 2016 10:44 am
last chance for me to put hydraulic ramps in the car today so please let me know if needed or they will stay here
Dan
Dbro4
Ex Vin#10223
Grey interior, Manual
Free flow
DJK73
VIN #: 10223
Postby mknowlton » Thu Oct 06, 2016 11:42 am
MikeWard wrote:Work list for the weekend;
Al
-door card re-foam
-dfog
-dreverse
-dlock and solenoids
-engine tune up
-check vac pipes ;)
Nick
-door card re-foam
-replace injectors
-replace ignition dizzy and rotor
-replace ignition leads
-engine tune up
-re-route accelerator cable under the heater box
-re-route rear speaker cable wiring
-solder earth tap for fog light switch into cigar lighter earth
-a/c re-gas
-re-fit centre console
-passenger door card re-foam
Julian
-door solenoids
-dlock
Mec
-door card re-foam?
dannyj75
-fuel system and fuel pressure check
-engine tune up
Feel free to add to this if I've missed anyone / any jobs.
Primarily I will be on hand to help out with Al and Julian's DLocks and solenoids but if there is time I would like to just check my emissions and fuel pressure.
Mike Knowlton (DBro 1)
DeLorean DMC-12, VIN#4208,
mknowlton
VIN #: 04208
Postby Admin-bloke » Thu Oct 06, 2016 4:20 pm
Consider it done Mike ;)
Postby bandit » Thu Oct 06, 2016 4:34 pm
It's gonna be mega again, I can feel it in me water
(That's watta Btw)
Postby mec » Thu Oct 06, 2016 11:15 pm
:thumbsup: :thumbsup: :thumbsup: :thumbsup: :thumbsup: :mrgreen:
Postby RobvdVeer » Fri Oct 07, 2016 7:33 pm
Have a great weekend!
Postby carl hammond » Sun Oct 09, 2016 9:41 am
I CAME, I SAW, I REAPED! :D
A massive thank you to Dan AKA Dbro 4 for sorting out my misfire (which in the end involved changing leads,dizzy,cap/arm & plugs) and all in under 2 hours - absolute top draw Dan!
Thank you also to Alistair for replacing my belt, which was well overdue a change. You know how much I like to hold onto my old belts though Al! ;)
Unsurprisingly, the car runs beautifully again now and didn't miss a beat on the way home.
Always great to see everyone again, as well as meeting some new members. Sorry I couldn't stay over for the duration this time, but a good laugh as always.
All the best
Postby arranj » Sun Oct 09, 2016 2:04 pm
Collection of images - the good ones are from Ryan on Facebook :)
Postby dannyj75 » Sun Oct 09, 2016 3:09 pm
Hi!
Firstly it was great to finally attend and meet everyone. Your wives definitely made mine feel welcome ( which is good as I am given the thumbs up for another meeting!).
A big thank you to Nick, Alister, Darren, Mike and everyone else I reaped from. The car was finally running right for the drive home. The car was as good as gold this morning so I would take that as problem solved.
Work done -
CPR changed - Nick to recalibrate my old one
frequency valve relay - better connections made.
Pressure spring re-shimmed 0.5mm shim. - Pressure now 5.3bar.
Throttle linkages adjusted correctly.
Air intake gasket leak fixed.
Mixture fettled to perfect running - Nick (the delorean whisperer)
reaping success! :D
Bills yet to be settle :shock:
dannyj75
VIN #: 3320
