Hi All
Sorry for the lack of updates of late, its been a bit hectic this end, anyway what have I been doing I hear you ask...
Fuel Tank Cleaned and installed inc internals
- 20190301_142511 (Medium).jpg (210.8 KiB) Viewed 6412 times
- 20190227_163214 (Medium).jpg (123.02 KiB) Viewed 6412 times
CV joints and caps refurbed
- 20190302_223110 (Medium).jpg (288.49 KiB) Viewed 6412 times
Rear Discs cleaned up and installed
- 20190302_223251 (Medium).jpg (172.53 KiB) Viewed 6412 times
Front and rear calipers Refurbed
Rear Before
- 20190302_223951 (Medium).jpg (314.79 KiB) Viewed 6412 times
Rear After
- 20190306_144557 (Medium).jpg (197.63 KiB) Viewed 6412 times
Front Before
- 20190307_110644 (Medium).jpg (290.27 KiB) Viewed 6412 times
Front After
- 20190406_115055 (Medium).jpg (222.19 KiB) Viewed 6412 times
New Fuel lines and original vac lines Painted
- 20190309_004607 (Medium).jpg (257.39 KiB) Viewed 6412 times
- 20190309_004618 (Medium).jpg (286.64 KiB) Viewed 6412 times
Drive Shafts Re-assembled
- 20190315_100257 (Medium).jpg (295.99 KiB) Viewed 6412 times
I have chosen a slightly different set of fans for my car, these are made by Pro Alloy for a Sierra Cosworth however with a few small mods they fit the De nicely, they use Spal Fans which are very nice quality..
- 20190319_123628 (Medium).jpg (253.6 KiB) Viewed 6412 times
Modded the corners of the frame to fit the De Rad..
- 20190328_142654 (Medium).jpg (204.37 KiB) Viewed 6412 times
- 20190328_142658 (Medium).jpg (193.11 KiB) Viewed 6412 times
Repainted and fitted to a new Rad
- 20190408_142900 (Medium).jpg (306.33 KiB) Viewed 6412 times
- 20190418_135926 (Medium).jpg (231.69 KiB) Viewed 6412 times
- 20190418_135951 (Medium).jpg (203.37 KiB) Viewed 6412 times
Lines fitted
- 20190418_140020 (Medium).jpg (221.53 KiB) Viewed 6412 times
Front and rear calipers installed
- 20190418_140034 (Medium).jpg (186.7 KiB) Viewed 6412 times
- 20190418_140048 (Medium).jpg (161.39 KiB) Viewed 6412 times
All new brake pipes made by hand
- 20190501_112246 (Medium).jpg (305.02 KiB) Viewed 6412 times
- 20190504_153725 (Medium).jpg (175.27 KiB) Viewed 6412 times
- 20190504_153804 (Medium).jpg (197.16 KiB) Viewed 6412 times
Right onto the gearbox, it has been stripped and checked internally and all new seals replaced but the cosmetic side was letting the side down so heres before
- 20190508_205440 (Medium).jpg (276.32 KiB) Viewed 6412 times
- 20190508_205541 (Medium).jpg (236.91 KiB) Viewed 6412 times
During after many many hours of wire brushing
- 20190513_222417 (Medium).jpg (245.87 KiB) Viewed 6412 times
Etch primed
- 20190513_224242 (Medium).jpg (202.11 KiB) Viewed 6412 times
Painted With POR15 Detail paint
- 20190516_083117 (Medium).jpg (245.63 KiB) Viewed 6412 times
I'l continue on the another post as i cant add any more pics
