MEC'S EPIC RESTORATION
Re: MEC'S EPIC RESTORATION
Postby hana 5284 » Thu Mar 07, 2019 12:13 am
MikeWard wrote:Nice one Mec, looks like it is coming along nicely, looking mint so far!
mec wrote:My lower wishbones have had the treatment with the reinforcing plates and collars added and p coated so same as the dukes (unless you mean the billet alu ones), i cant afford them :dance:
I think Tyson means the control arm supports, i.e. these: https://www.deloreango.com/uk/front-low ... -pair.html
yes you are correct mike I was unsure the tec name for them but I must say they look mint and if they do what they say should improve handling.
cheers
tys
Postby mec » Sun May 19, 2019 3:31 pm
Hi All
Sorry for the lack of updates of late, its been a bit hectic this end, anyway what have I been doing I hear you ask...
Fuel Tank Cleaned and installed inc internals
20190301_142511 (Medium).jpg (210.8 KiB) Viewed 6632 times
20190227_163214 (Medium).jpg (123.02 KiB) Viewed 6632 times
CV joints and caps refurbed
20190302_223110 (Medium).jpg (288.49 KiB) Viewed 6632 times
Rear Discs cleaned up and installed
20190302_223251 (Medium).jpg (172.53 KiB) Viewed 6632 times
Front and rear calipers Refurbed
Rear Before
20190302_223951 (Medium).jpg (314.79 KiB) Viewed 6632 times
Rear After
20190306_144557 (Medium).jpg (197.63 KiB) Viewed 6632 times
Front Before
20190307_110644 (Medium).jpg (290.27 KiB) Viewed 6632 times
Front After
20190406_115055 (Medium).jpg (222.19 KiB) Viewed 6632 times
New Fuel lines and original vac lines Painted
20190309_004607 (Medium).jpg (257.39 KiB) Viewed 6632 times
20190309_004618 (Medium).jpg (286.64 KiB) Viewed 6632 times
Drive Shafts Re-assembled
20190315_100257 (Medium).jpg (295.99 KiB) Viewed 6632 times
I have chosen a slightly different set of fans for my car, these are made by Pro Alloy for a Sierra Cosworth however with a few small mods they fit the De nicely, they use Spal Fans which are very nice quality..
20190319_123628 (Medium).jpg (253.6 KiB) Viewed 6632 times
Modded the corners of the frame to fit the De Rad..
20190328_142654 (Medium).jpg (204.37 KiB) Viewed 6632 times
20190328_142658 (Medium).jpg (193.11 KiB) Viewed 6632 times
Repainted and fitted to a new Rad
20190408_142900 (Medium).jpg (306.33 KiB) Viewed 6632 times
20190418_135926 (Medium).jpg (231.69 KiB) Viewed 6632 times
20190418_135951 (Medium).jpg (203.37 KiB) Viewed 6632 times
Lines fitted
20190418_140020 (Medium).jpg (221.53 KiB) Viewed 6632 times
Front and rear calipers installed
20190418_140034 (Medium).jpg (186.7 KiB) Viewed 6632 times
20190418_140048 (Medium).jpg (161.39 KiB) Viewed 6632 times
All new brake pipes made by hand
20190501_112246 (Medium).jpg (305.02 KiB) Viewed 6632 times
20190504_153725 (Medium).jpg (175.27 KiB) Viewed 6632 times
20190504_153804 (Medium).jpg (197.16 KiB) Viewed 6632 times
Right onto the gearbox, it has been stripped and checked internally and all new seals replaced but the cosmetic side was letting the side down so heres before
20190508_205440 (Medium).jpg (276.32 KiB) Viewed 6632 times
20190508_205541 (Medium).jpg (236.91 KiB) Viewed 6632 times
During after many many hours of wire brushing
20190513_222417 (Medium).jpg (245.87 KiB) Viewed 6632 times
Etch primed
20190513_224242 (Medium).jpg (202.11 KiB) Viewed 6632 times
Painted With POR15 Detail paint
20190516_083117 (Medium).jpg (245.63 KiB) Viewed 6632 times
I'l continue on the another post as i cant add any more pics :lol:
Postby mec » Sun May 19, 2019 4:00 pm
OK CONTINUED FROM LAST POST
So then we come onto the engine, there was nothing really wrong with it before it was removed just like to leak oil from various places so thats been addressed
The Sump has been removed, cleaned and refitted with a new gasket, also the rocker covers, front crank case have had the same treatment, cleaned with all new gaskets, the rear main sill replaced along with the housing gasket and the front crank sill also replaced.
Whilst i was there the block was looking a bit tired from when i painted it so thats now had new paint and also since the attached pic its had 2 coats of high temp laquer too.
20190514_153620 (Medium).jpg (297.87 KiB) Viewed 6630 times
20190514_164815 (Medium).jpg (164.92 KiB) Viewed 6630 times
20190514_200713 (Medium).jpg (231.38 KiB) Viewed 6630 times
20190514_201722 (Medium).jpg (220.93 KiB) Viewed 6630 times
20190514_232359 (Medium).jpg (171.06 KiB) Viewed 6630 times
20190515_214725 (Medium).jpg (236.76 KiB) Viewed 6630 times
20190516_083139 (Medium).jpg (180.02 KiB) Viewed 6630 times
I have installed all new exhaust studs and of course new manifold gaskets too
Before the chassis went to be dipped i traced the original number off the back of it so it could be reinstated, Gem traced it back on for me so i could re write it in marker pen just like the factory did..
20190518_111604 (Medium).jpg (265.94 KiB) Viewed 6630 times
20190518_111620 (Medium).jpg (136.22 KiB) Viewed 6630 times
20190518_112535 (Medium).jpg (187.15 KiB) Viewed 6630 times
Then Yesterday the Chassis rolled on its wheels for the 1st time in over 6 months
20190518_133625 (Medium).jpg (411.13 KiB) Viewed 6630 times
20190518_133616 (Medium).jpg (376.42 KiB) Viewed 6630 times
20190518_133558 (Medium).jpg (366 KiB) Viewed 6630 times
20190518_133548 (Medium).jpg (364.98 KiB) Viewed 6630 times
So then we come to today, the engine and box are now together
20190519_075232 (Medium).jpg (280.79 KiB) Viewed 6630 times
This is now in the chassis and my old mate Alex came over this morn for some "Body" Action ;)
20190519_093922 (Medium).jpg (226.1 KiB) Viewed 6630 times
20190519_094437 (Medium).jpg (237.98 KiB) Viewed 6630 times
20190519_094701 (Medium).jpg (278.44 KiB) Viewed 6630 times
20190519_094845 (Medium).jpg (236.79 KiB) Viewed 6630 times
20190519_095741 (Medium).jpg (267.71 KiB) Viewed 6630 times
20190519_100927 (Medium).jpg (246.7 KiB) Viewed 6630 times
So the Eagle has landed !!
20190519_103016 (Medium).jpg (237.8 KiB) Viewed 6630 times
20190519_115124 (Medium).jpg (284.02 KiB) Viewed 6630 times
Now i just gota work out how the rest of it goes back together !! :shock: :dance: :dance: :dmcdoors: :dmcdoors:
Postby Red5ive » Sun May 19, 2019 4:42 pm
As said by many others -Inspiring stuff. You two are legends!
Final stretch now, will it be ready for June tech??!!
Red5ive
VIN #: 4468
Postby mec » Sun May 19, 2019 4:58 pm
Fingers crossed, we will see :pray: :pray:
Postby Admin-bloke » Sun May 19, 2019 5:17 pm
Excellent work :thumbsup:
Postby MikeWard » Sun May 19, 2019 5:26 pm
It's looking mint mate, really great work there, keep it up, you're on the finishing straight now!
Postby Dan 6511 » Sun May 19, 2019 6:22 pm
Bloody hell mec that is quick work. It's going to be back on the road before mine at this rate, dunno how you find the time!
Great work though, looking really good. Bet its a weight off your mind having the body back on and it rolling again instead of a pile of bits.
Postby mec » Sun May 19, 2019 6:50 pm
Thanks guys, yea ive put in some long hours particularly this week to try and move things on a bit :mrgreen:
Postby bandit » Mon May 20, 2019 5:25 am
Looks shit hot mate, nice touch with the marker pen
