Different Engines
Re: Different Engines
Postby dmc4087 » Fri Jun 13, 2014 12:58 pm
That VR6 conversion over on dmctalk would be the ticket. It leaves plenty of room around the engine unlike some of the V8 conversions, and it must weigh a fair bit less too.
Postby Manxmann » Fri Jun 13, 2014 1:13 pm
That engines too long for the Scim never mind the D, the guys going to need to be in the back seat to change gear!
Go back to the D's roots and put in a Wankel :D
The Manx 'D' - VIN 17152
Manxmann
VIN #: 17152
Postby Manxmann » Fri Jun 13, 2014 1:15 pm
The VR6 is impressive, but under powered in NA form (170Hp in later OBDII form). A better one would be the enlarged 3.2 VR6 in the R32 (250Hp) or better yet US R36 (270Hp).
OR
Go completely left field what a bout a W8 from a passat?
Manxmann
VIN #: 17152
Postby Dan 6511 » Fri Jun 13, 2014 2:45 pm
Or leave it alone and buy another car that actually goes round corners ;)
Postby arranj » Fri Jun 13, 2014 4:39 pm
From Tyson:
This is a guy in Oz called Nick Holden. He doesn't know what the engine is, but it isn't stock :)
The guy is on Facebook
Postby Dangermouse » Fri Jun 13, 2014 5:11 pm
That's a 6 litre Chevy LS2 engine. 400HP.
Nick H has a D, but is that his?
There is, perhaps unbelieveably, another LS2 conversion ongoing in Oz:
http://v8timemachine.blogspot.com.au/
And this is Nick R's LS1 car in the US. Only 350HP
Postby Starglider » Fri Jun 13, 2014 8:41 pm
Manxmann wrote:Go completely left field what a bout a W8 from a passat?
If I hadn't gone for the Legend-style engine I would have tried swapping in a W12 from a first-gen Phaeton. Would probably do horrible things to the weight distribution and be hell to integrate, but it would be awesome. :)
Starglider
VIN #: 12306
Postby mec » Fri Jun 13, 2014 10:18 pm
Dan 6511 wrote:Your engine blown up mec? Didn't put it in first gear on the A12 did you ;)
Naaa my engine is OK Dan, well OK ish, its pissing oil out of everywhere, only starts on 2/3 cylinders every now and then and I just thought it might be nice to have sumit a little bit more 'turn key'
that LS2 engine looks the nuts !
Postby Admin-bloke » Sat Jun 14, 2014 7:26 am
It looks so right in a black painted frame too!
