Postby Domi » Sat Apr 23, 2016 5:23 pm
Just did a little painting on the bracket
Postby RobvdVeer » Sat Apr 23, 2016 5:40 pm
I notice the full scale wiring diagram poster, just as i have on my garage wall. Love the pictures of the progress!
Postby Domi » Sun Apr 24, 2016 5:28 pm
Thanks!
Finally removed the old stereo unit
Postby Domi » Sun May 01, 2016 5:45 pm
New spire nut
POR15
And POR15 everywhere to avoid rust in the future
New rock screen
Postby Domi » Thu May 05, 2016 12:17 pm
Second layer of POR15
And add a new ground to the ECU
Postby Domi » Sat May 07, 2016 8:24 pm
Painting... again :mrgreen:
I had to remove POR15 on the bracket because it didn't hold on. So, now I wonder if I try to paint it black or invisible paint to protect it like it is now.
A little bit tired after all the work done so far... :mrgreen:
Postby Domi » Sun May 08, 2016 5:01 pm
Just changed the ground wire from the battery
The old one was rusty
Finally painted black anti rust
Postby Domi » Sat May 14, 2016 7:49 pm
The radiator and fans and back on the car, not so easy lying under the car
Replacing the bracket, new horns with stainless bracket and also stainless bracket for the radiator.
I’m trying to mount the radiator duck, but not so easy to do it. On side only is okay for now.
When you take a look on Ed’s site or Houston it’s a two part component now?
We’ll see that tomorrow, after 4 hours of working on the car, I’m a little bit tired.
Postby Domi » Sun May 15, 2016 6:59 pm
After a few hours, the radiator duct is finally mounted back.
And the last stainless pipes are now back in place
Postby Domi » Mon May 16, 2016 4:49 pm
I wanted to redo the level of clutch fluid today and despite the valve is operating, nothing comes out?
Without the valve, the liquid reaches well, so I assume that the valve is defective.
I do not know if I can find it here or if John can provide me another in exchange.
Otherwise, I installed my new gas line, which should prevent leaks at the filter.
Users browsing this forum: No registered users and 35 guests
