I've removed the thermostat housing and thermostat. I noticed that there must have been a lot of air inside because the top inside of the housing felt dry, and my garage floor wasn't soaked in coolant.
I'm not sure anymore, but i have the feeling is was installed upside down (??) Now if it were upside down, that would certainly explain a lot.
I checked the thermostats working by boiling it. It starts opening around 79C as by specification on the hardware, so that is working fine.
Anyways I had to remove the ram horns as well, but there a separate thread for that.
- IMG_0114 (Medium).JPG (78.41 KiB) Viewed 3520 times
- IMG_0116 (Small).JPG (27.48 KiB) Viewed 3520 times
- IMG_0119 (Small).JPG (23.26 KiB) Viewed 3520 times
